Gambit80's avatar
Gambit80
WDH Question
We upgraded from our original TT, a 20' Keystone Hideout to a 26' Salem TBUD last year and have decided to upgrade our WDH. I currently have the original round bar WDH with friction sway control bar.
Am currently looking at various 4 point sway control types, but I want to be sure I looking at correct WDH bars.
Gross weight of RV: 7800 lbs
7800 x .13 = 1014 lbs
Weight in truck bed: 200 lbs
1014+200 = 1214 lbs
So I would be looking at a WDH with 1200 lb bars, correct?
Thanks!
  • I have been towing with it for over a year and I can tell it is not quite right and have adjusted it two or three times.
    We are going on a cross country trip from Florida to Yellowstone later this year and I want to have the most correct setup, which is why I am looking at upgrading.
    I am looking for better sway control than just a friction bar for a 29' TT.
  • Tvov's avatar
    Tvov
    Explorer II
    You've got a good truck and your existing hitch might work just fine - right near the top, but should work. Have you tried towing with it? If you are not happy with the original hitch, certainly get a new one!
  • I've been using the Anderson no sway hitch, and so far I like it.
    With your truck and trailer you wouldn't need to move A lot of weight foward so I think it would be a good candidate.
  • It is rated for 1000 lbs. It is a Curt round bar system.
  • Tvov's avatar
    Tvov
    Explorer II
    What is your original WDH rated for?
  • Thanks, downtheroad.
    Blue Ox is on the list, as well. Just trying to weight all the factors out.
    Thanks for the check on the numbers.
  • Don't rule out Blue Ox SwayPro either.
    Much quieter (silent), much easier to set up, superior sway control.
    Lots of bar weight choices.
    But, to answer your question: yes, 1200 lb. bars for your rig.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
