bjkb1f's avatar
bjkb1f
WDH Questions
I took my truck and TT to the CAT scales and have a few questions about the number. Hoping you guys can help.
TV is a 2018 F150
TT is an Alpha Wolf 26DBH
I know my TT is just about as big as you’d want to go with a half ton. So I want to make sure I load it correctly.
Unloaded truck wt - Front: 3120 Rear: 2520
Coupled with no WD: Front: 2680 Rear: 3960 Trailer: 5540
Coupled with WD: Front: 2920 Rear: 3640 Trailer: 5640
TT weight: 6540 loaded but with empty tanks
Based on my math, my tongue weight is right at 1,000 lbs - coupled/no WD weight on truck minus unloaded truck weight. That is the correct way to calculate this right?
Second, it looks like the hitch is only putting about 100 lbs of the tongue weight back on the trailer axles.
Third, I’m still not back to my unloaded weight on the front truck axle.
I assume I should adjust the hitch a bit more to get more weight distribution. Is that correct? My front wheel well distances are within the recommended range but it’s still about a half inch higher when hitched with WD than unloaded.
My plan is to move some of our **** to the rear storage compartment and adjust the hitch to get the tongue weight closer to 13% (right now it’s just over 15%) and further distribute the weight to the front and trailer axles.
I’m below all weight limits (axles, tires, hitch) but getting close on payload so I’d like a little more wiggle room.
Thoughts?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
