nobozo's avatar
nobozo
WDH selection/trailer loading advice.
Newbie would appreciate some help:
I need some help selecting the correct product for my 2010 F-150 with factory integrated brake controller. I have a 20' equipment trailer rated at 14,000 pounds. It will be used (rarely) to haul construction equipment (typically a skid steer). The weight of the machine (with bucket) is 9,000 lbs. The trailer weighs 3,000. Additional equipment on the trailer could bring the weight up to the max trailer rating of 14K. I have previously towed such a loaded trailer without a WDH. The tongue weight of the trailer was controlled by positioning of the equipment just forward of the axles. I probably maintained less than 500 lbs. on my hitch as the suspension on the unmodified vehicle did not compress more than a couple of inches.
I am considering an Equal-i-zer (with sway control) 90001000/90001200/90001200. I understand that if I select a "heavier" unit the ride quality may suffer and affect trailer control. I also intend on installing air bags with automatic height adjustment. I would appreciate some guidance. Should I go with the lighter unit (90001000) and load the trailer to maintain tongue weight near the hitches' max rating (1000 lbs.), or go heavier? As I said I can load the trailer appropriately, even to the point of negative tongue weight.
Eventually, I will be adding an RV to my fleet (I'll probably go big). I don't intend on towing such a trailer across country with my F-150 but I imagine the tongue weight will exceed that induced by my equipment trailer. If I go on the lighter side (which is my guess for the equipment trailer) can I upgrade my hitch by adding "stiffer" tension bars later?
Obviously, I lack knowledge in this area and am aware that I haven't been utilizing the proper equipment.
  • It sounds like your pushing the limits of your F150. I'm sure others will jump in here. I do use an equalizer brand hitch and it works will for me. My load is much lighter then yours. I was told by the manufactories the the hitch weight rating was the most important consideration. Sounds like you can adjust this figure by positioning your load. You might want to call the people at Equalizer. I did and I found them to be very helpful. Good
    Luck.
