Chaos wrote:
I have another hole I can drop on my current shank. I am out of tilt on the head. Reese says my spring bar ends should be 9.5 inches from the ground. If I drop down to the bottom hole, I can not get 9.5 inches of clearance.
Can't you lower the ball mount and then
decrease the amount of rearward tilt and decrease the number of chain links under tension?
You previously reported being "On eight links". I assume that means eight links under tension.
Reese says you should have at least five links between hook and u-bolt, so you could try reducing the amount of rearward tilt and going to 7 or 6 or 5 links.
I don't believe the 9.5 inches of clearance is mandatory. I think Reese just suggests that as a starting point for ball mount height adjustment.
Ron
