BenK wrote:
The OP is bit ahead in the process
Need or suggest to understand the 'goal' of it all...including weights vs ratings
Decide if you believe in the ratings or not
I will be following all the ratings, as required by law.
If not, then do whatever but note that over the ratings may have warranty denied...if
they find out
If yes, then go out and weigh the whole setup. Axle by Axle both fully loaded
and empty
I can't do that until I get the hitch set up. Can't tow it anywhere without a hitch.
Why would empty weights matter at all? I will never run it empty.
Read up on the HOW2's and understand them
I have been reading and I'm doing my best.
The OP is adjusting without knowing where they are in reference to their ratings
and unknown to us is the orientation of the setup
What do you mean "the orientation of the setup?"
I like to have the trailer level at it's highest pointing and preference to
have it pointing slightly down
I do not comprehend. At all.
Moving the shank/head without knowing the orientation is useless
Tilting the head is a ditto and note that tilting the head is to gain more
WD spring bar (either round or trunnion) distance to increase their preload
Tilting it back towards the trailer is the right way. Tilting it forward removes
WD spring bar preload potential
The height of the shank/head is determined by the final orientation of the
trailer and the TV
The front end height as instructed by the manual is out of context without
knowing the weights, the spring bar ratings, etc
OP, please post these ratings and actual weights: front GAWR/GWR, rear GAWR/GWR,
GVWR and the actual weight of the trailer. The trailer dry weight is not helpful,
but it does provide a range of the tongue weight vs the actual weight
Again, I cannot take it to a scale to get the weights until the hitch is set up. I am using the tape measure method, as instructed by the hitch and vehicle manufacturers. I could post my ratings, but they would not provide any useful information.
Once I get everything set up, I do plan to take it to the scales.
