myredracer
Mar 28, 2016Explorer II
bbaker2001 wrote:
yes no problem with air flow,
yes it does not seem to get hot enough. I am looking at maybe taking off the regulator. not sure what size it comes with. I ordered a 20. I might try that in line. just seems like not enough flame pressure. thought of drilling out the holes.
if I find a solution, I will let you know.
I took the regulator off ours and are running off a quick connect on the line under our trailer. Same as our old Coleman, just seems to have a bit of a lazy flame - not quite enough pressure I guess. Our stove inside is around 25' or so away from the tanks and works just fine. Maybe the answer is drilling out the holes and would be interested to hear if that helps.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
