georgelesley
Feb 18, 2017Explorer II
Weighed MH
Driving a few days ago we came across an empty weight station that was open. I pulled in and asked if they would weigh us. They said sure, and a few minutes later we knew that our front axle weighed 6800lbs and is rated for 8000. The rear weighed 12800 and is rated for 15000. With those margins I am not particularly concerned about actual corner weights.
At a gross weight of 19600 and pulling a toad that weighs less than 3000lbs, we are well within the total weight of 26000 lbs for our chassis.
I know I could check actual tire ratings but since it still has the factory original Michelins and we have good safety margins, I am not real concerned about that. We both feel much better and it was simple and free. If you wonder about your weights when actually loaded, I recommend you look at weigh stations. Now with the easy pass many trucks have they are often not very busy.
