jgos929's avatar
jgos929
Weight causing tires to rub inside of trailer
When my Maverick (utv) is loaded in the garage of my toy hauler its causing the trailer to sag... naturally. But this past weekend I had a blowout and discovered it was because when going around turns on winding roads the extra weight was causing my tires to rub on an aluminum boxed area of the trailer that sits just above and to the inside of the tires. When going straight down the highway all is fine it seems to only rub when weight is shifted side to side. Im well within the cargo capacity of my trailer when loaded so my question is, is there anything I can get to control the sag or help with the side to side weight that will keep the tires from rubbing? I've done a little searching and all I've found is Timbren Trailer enhancements. Has anybody used these? If so is this the answer to my problem or is there something else I should be looking at?
Thanks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
