the_bear_II
Feb 19, 2014Explorer
You might want to check your tires to see if you have had belt separation... It can cause the tire to bulge at the middle of the tread enough that the tire(s) will rub. Your tires should be flat across the tread, if they are rounded then you have belt separation and this will cause a blowout or tread separation.
I had two tires bulge by over an inch on my previous set.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
