Tireman9
Mar 09, 2014Explorer
MM49 wrote:Fisherguy wrote:MM49 wrote:
The trailer might of had the LT tire change done on it.
MM49
What's that sposed to mean?
When LT tires are installed on a RV a larger size is required to meet the load requirements. Correct This could be the source of the clearance problems. Also Correct unless axle to frame measurements have changed.
The LT tires are also a different compound that increases the traction to the road. Could you provide your test data to support this theory? This could cause the larger tire to rub during a turn from the tire not sliding as required.
The larger tire is also a lever that flexes the axle during a turn, longer lever, more axle flex, more tire movement.
Overall it's not a good idea to change the tire size from the OEM's selection.
MM49
Since we are talking Lateral traction forces, you do realize that running lower inflation than tire max can result in an increase in those forces.
Also if a frame is designed so close to the limit they are knowingly selling a product that cannot tolerate normal stresses seen in normal usage. Different road surfaces across the US have measured traction coefficients that vary by over 200% so a few % variation from different tires is not meaningful when we are talking frame failure. I again ask who has filed a complaint with NHTSA and provided vehicle VIN # in the last 2 years?
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
