Ivylog
Feb 04, 2017Explorer III
lenr wrote:
I used WD towing our 6,000 lb. bumper pull with our 2012 F-350 Diesel just to put factory designed load back on the steering axle for better handling and less tendency to sway.
Depending on wheelbase a disel F350 will have aprox 4500lbs on the front axle and 3000 on the rear without a load in it... so you are saying it will handle better with the front axle 1500lbs heavier than the rear.:S
I would want at-least 1500lbs of load on the rear axle to get a 50/50 weight BALANCE.
OP, NO YOU DO NOT NEED or want WD.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
