BlunderLust's avatar
BlunderLust
Weight distribution / anti-sway hitch recommendations
I've found some great travel trailer models thanks to the most helpful folks here. To tow the trailer I think I'll need weight distribution and anti-sway hitch add-ons. A trailer I'm considering is the Nash 17K with a weight of 4400 lbs and NCC of 2600 lbs. My truck is a 2015 Ford F150 SuperCab 3.5L EcoBoost 4x2 145" Wb 3.55 axle ratio. Ford states this version of the F150 has a max trailer weight of 12,100 pounds so I should be OK with the weight even with a maxed out NCC and Ford has overstated the actual tow capacity.
For such a truck/trailer combination is there a specific brand/model of weight distribution / anti-sway hitch which is recommended? Thanks!
  • This will be our 4th season with the Reese dual cam (with trunnion bars) and I really like it a lot. It took a full season of tweeking it to get it working the way I wanted. Besides the WDH, we installed Bilstein shocks on the truck and shocks on the trailer and together with the Reese DC, works great. No sway or handling issues anymore.
    I have been looking and looking while at CGs for someone else with the same dual cam WDH and have only seen one. Unless you were to use RV forums, you likely wouldn't know about the different WDH brands and options. Many will just use what a dealer says is good.
  • I almost purchased a trailer which included the Equal-i-zer system and from what I read and watched on YouTube it looked pretty good and LOUD. I'll definitely be checking out those Blueox SwayPro and Resse Straight Line / Dual Cam options. Thanks everyone.
  • Community Alumni's avatar
    Community Alumni
    My Blue Ox performs very well. It's clean, quiet, no fiddly adjustments, and does a great job of controlling sway. The Andersen and the Reese Straight Line are good alternatives.
  • I'm curious about your truck's payload. Typically, the rating limit reached first is not the "towing limit", but is the "hauling limit". The tongue weight of a 12,100 lb. trailer (1200-1800 lbs.) combined with the weight of the passengers and cargo in the truck would exceed the chassis weight rating (GVWR) or rear axle weight rating (REAR GAWR) of most F150 pickups.
    Your proposed 4400 "brochure weight" camper will likely be 6000 lbs. with options, propane, batteries, water, food, tools, outdoor chairs, etc. The tongue weight will likely be in the 720-900 lb. range.
  • jerem0621 wrote:
    .....snip.....
    I bet I see 10-1 ratio out there. 10 standard to 1 integrated...just my casual observations.
    Jeremiah
    I suspect Jeremiah is pretty close to right on that. I look all the time both in campgrounds and on the road, and most seem to run a basic standard WD hitch with added on sway bars. Must work for most folks.
    I will say I continue to be happy with my BlueOx swaypro. Coming up on 30K miles towing with it, and it works as advertised.
    I'm not looking at the vehicle right now but as I recall the cargo capacity is a bit over 2,100 pounds - 2,179 pounds comes to mind.
  • I reviewed videos on the Husky Center Line, Equal-i-zer, BlueOx SwayPro, Anderson No Sway, and Reese Straight Line, and Reese Dual Cam options. I'm passing on the Dual Cam option due to clearance. Anderson seems to have the best clearance but reconnecting the hitch requires the ratcheting down of the red springs. It almost seems like a reinstall every time you connect it as I believe the spring tension dictates the weight distribution on the axles (remeasuring the height of the front/rear fenders). Anderson also has the extra maintenance of the brake pad insert and the triangle plate looks like it could be bent fairly easily. Equal-i-zer connect/disconnect looks nice and simple but it seems to be quite noisy. BlueOx appears to have a clearance similar to the Equal-i-zer, no grease on the bars, and supposedly very little noise. Then there is the Husky Center Line which looks similar to the Equal-i-zer but includes a more advanced sway control system and according to Husky is quieter than friction based sway control. Though Husky seems to have the best features no one is recommending it so BlueOx might be the safe bet. Thanks!
  • This is going to be my next WD setup and since fairly new...will take time for
    info to come back. So far, most are very positive
    I'd not jack knife while backing up...that will bend one of these spring bars
    That is part of how it works...pushing back on the trailer getting it back in
    line with the TV...but while backing up, you might want to jack knife the setup
  • Check out the Reese SC system! Very similar to the Equal-I-Zer 4 way system, by Reese uses a brake pad material for friction that the bars ride on. From what it sounds like from reviews it is a little quieter than the Equal-I-Zer system. The Reese hitch head has a little more fine tune adjustability as well...
    Good luck!!
