skipnchar
Jun 30, 2013Explorer
You ALSO might want to do some towing with it full and empty before you make that decision since if your FW tank is in the front, they MAY be a reason for it being there. could be your tongue weight is heavy enough only with it full. Some smaller trailers build in ballast by using the tankage for the purpose. Once you find out how it tows best and what your weights are, then as suggested, set it up in that mode. IF your trailer is not a small one, then you can likely forget about the issue as weight distribution is not usually a concern.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
