waterman7474's avatar
waterman7474
Weight distribution hitch BARELY won't fit into receiver
I have a small-ish 18ft travel trailer that I have a distribution hitch for. I normally tow it with my tundra but we wanted to tow it the other weekend with our '12 4runner (factory receiver).
The problem is the hitch is just barely too big to fit into the receiver. The receiver will fit a normal 2in hitch just fine, this thing makes it about half way in and stops, almost like it is tapered toward the back.
Since it is a little loose in the Tundra receiver, I thought it was paint or powder coat and scraped some out, but still a no go. Called a trailer place and he was stumped. Suggested a hit it with a grinder and take a little off and see if that worked, couldn't get much off as it is very hard material but still no dice.
Is there something I am missing here?
  • Have you thought about running to the nearest Toyota dealer and checking a different 4 Runner?
  • You might have dodged a bullet here- the only 4Runners that had frame-mounted receivers rated for use for W/D were the V8's. Since they didn't put those out in 2012, I'm assuming you have the V6- factory hitch on that model is NOT for W/D. It should say so right on the receiver, and probably also in your owner's manual. Reason is method of mounting- the OEM's on the V6's are attached to the rear cross member only, whereas the W/D receiver on the V8 models mounted directly to the frame rails. This in order to deal with the rotational stress torque imposed by W/d systems.
    That said:
    It does seem unlikely that a (2"?) hitch bar itself wouldn't slide into the receiver for that reason unless Toyota actually built in some feature to prevent their use. If W/D's shank is longer, for example, than a standard weight-bearing ballmount, the smallest of curvatures in the receiver tube would do just what you describe- prevent full insertion.
