eHoefler
Jun 07, 2014Explorer II
newman fulltimer wrote:
You need a bigger hitch
Agreed!! Also, look at the manufacturer ratings for the coach's towing capacity, it may be below the hitch rating. Any rig will benefit from an equalizing hitch, just because you may have an air ride suspension that will compensate for squat, does not mean weight has not been removed from the steer axle. A Weight Distributing Hitch is designed to transfer weight back to the steer axle, as a benefit, it also helps with rear axle squat.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
