Rollnhome
Jun 07, 2014Explorer
Freightliner said to call Fleetwood. Fleetwood did the math, then supplied and installed the receiver. Freightliner considers it aftermarket install. The more I look into it the less scence it makes. The purpose of WDH is to level the ride, thereby distributing the load evenly. It does not reduce the tongue weight, if anything it appears to increases it. If the air bags level the load then why the need for WHD to level the load. From a laymans position the WDH does not reduce any stress on the frame any more than the leveling done by the airbags. The axle weights are with in spec so ?????? I"ll see what Fleetwood says Monday.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
