CrowsnestGuy
Aug 12, 2015Explorer
CrowsnestGuy wrote:
Just another quick question.
When you size your WDH do you include the weight you put in the back of the truck like firewood, generator etc? As well as the tongue weight?
Thank you.
Ok Google helps. Answered my own question.
Gross Trailer Weight (GTW) refers to the weight of the fully loaded trailer in its actual towing condition.
GTW is measured by placing the fully loaded trailer on a vehicle scale.
Rating of weight-distribution system must match or exceed your GTW.
Tongue Weight (TW) refers to the tongue weight of your trailer plus the weight of the cargo that sits behind the rear axle of your vehicle.
Trailer TW is measured using a tongue weight scale
Typically, about 10 to 15 percent of GTW
Weight of cargo behind the rear axle can be measured using a commercial scale
Weigh vehicle without cargo
Weigh vehicle with cargo loaded
Subtract initial weight from weight of loaded vehicle
Getting TW for Weight-Distribution Systems
Tongue Weight (for weight distribution) = trailer tongue weight + vehicle cargo load behind rear axle
The TW rating is the most important factor in determining which size weight-distribution system you should use. If the bars of the system you choose are rated too high for your setup, they will create a rigid ride, which can result in a bouncing trailer. If, on the other hand, the bars are not rated high enough, the system will be unable to properly distribute the weight, rendering it virtually useless.
Here's an example:
If you have a trailer that has a TW of 700 lbs, and your vehicle has 100 lbs of cargo in the trunk, then your overall, weight-distribution TW is 800 lbs. Choosing a weight-distribution system with a 1,500-lb TW rating may lead to erratic performance because it is rated too high. On the other hand, if you choose a system rated too low, say at 500 lbs, the system would be ineffective. Choose a weight-distribution system with a TW rating that is closest to your towing setup's TW to ensure the best performance.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 26, 2025
