LibertyMan
Jul 19, 2019Explorer
I pretty much have the same set-up as you, 35ft. travel trailer and pull it with a Ram 2500. At first I did not like the set-up either until I started playing with it and getting some good cat scale weights. The eaz-lift 1200lbs distribution bars distribute the weight well, cat scales have confirmed that. But instead of using one friction sway control, I have two on mine. It has pretty much removed nearly all sway. The most important thing to help with sway is having around 15% of the trailers weight as tongue weight. And of course, not drive like a bat out of hell. For around 60 bucks, I would try a second sway control before dropping 2K on another hitch. If it does not work out, then you can spend the big money. Hope this helps some.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
