blt2ski
Jul 20, 2019Moderator
The best one is the one adjusted correctly, with trailer balanced etc correctly.....The worst, even if a Hensley, the one not setup correctly, with a trailer that is setup so it will fishtail sway on its own, or equal issue that the bar system in use, Will mask or hide an incorrectly set up trailer.
One should be able to pull a given trailer with out bars at 60+ mph etc using finger tips steering. Now add bars for added safety. If you can not pull trailer using ONLY finger tips on wheel, you have issues bars will not fix or solve!
Marty
Marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
