sgfrye
Sep 20, 2019Explorer
LibertyMan wrote:
I pretty much have the same set-up as you, 35ft. travel trailer and pull it with a Ram 2500. At first I did not like the set-up either until I started playing with it and getting some good cat scale weights. The eaz-lift 1200lbs distribution bars distribute the weight well, cat scales have confirmed that. But instead of using one friction sway control, I have two on mine. It has pretty much removed nearly all sway. The most important thing to help with sway is having around 15% of the trailers weight as tongue weight. And of course, not drive like a bat out of hell. For around 60 bucks, I would try a second sway control before dropping 2K on another hitch. If it does not work out, then you can spend the big money. Hope this helps some.
x2 on this.
i have the same hitch as your current one with one sway bar. our TT is 38ft, approx 9500 to 10k lbs loaded to camp.
my truck is a ford f250 gasser 6.2 with 3.73 rear end.
i have towed it up and down the east coast, mountains to the coast. very little to no, sway in winds and large trucks passing us on highway.
tows like a dream. i took the hitch off our first TT that we traded in, it was 33ft and approx 7500lb catscaled ready to camp. it did not tow any better than current TT honestly not as well.
the key difference for me is that on the current TT hitch installation we had it done by a 25 year veteran rv tech. he really spent a good amount of time getting it setup properly with the truck hitch head.
another question is what type floor plan do you have? our first TT was rear kitchen which caused more weight behind axles, leading us to move as much weight forward as possible. current TT is rear living with most weight over axles. another reason it seems to tow better, especially with black tank, and bathroom grey tank almost full
its a tried and true hitch system.
to each his own and im sure the expensive hitches are great but for my money i would try to adjust your current one or add another sway bar before spending the extra money.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
