fugawi's avatar
fugawi
Explorer II
Sep 12, 2013
Weight dist/sway system you don’t need to install every time
I am planning to purchase a toy hauler. It would be about 7,000 lbs/30’ as travel trailer or 8,000 lb/31’ as 5th wheel.
I’ve read many, many posts regarding travel trailer vs. 5th wheel to get a sense of pros/cons.
I’m going to get a new tow vehicle, so I could get a truck for 5th wheel.
I would prefer the travel trailer for single level and for lower top height. I would also prefer a large SUV like Expedition.
Regarding the travel trailer option, can someone tell me if there is a simple, quick approach to weight distribution and sway control that doesn’t involve putting on/talking off the separate gear each time you hitch/unhitch trailer? Is there any sort of effective "built-in" weight distribution/sway system?
From an efficiency standpoint I really prefer to not have that extra step every time I connect/detach trailer.
If there is not a quick, simple approach for travel trailer weight distribution and sway control, am I better to go with the truck and 5th wheel. Is that hitch/unhitch process more efficient/quicker?
Thank you.
  • Equilizer hitch is a typical WDH hitch with built in sway control. No need for separate sway control friction bars.
  • Look at the Blue Ox sway pro also. I replaced a Reese WD hitch with separate sway control with it and its much easier to use.
  • If you are spending thousands already, than you might want to take a look at a hensley. the hitch stays on the trailer and after a few times hooking up you will have it mastered. jmo
