yellowdog00's avatar
yellowdog00
Weight rating of fifth wheel hitch
Looking to purchase my first fifth wheel slider hitch. The fiver I am looking to pull has a GVWR of 14,900. The Pull rite slider hitch I'm looking at comes in a 16K and 18K model.
Is there any advantage going with the heavier 18k model or will th 16K suffice?
Thanks!
Mike
  • YellowLab wrote:
    To Kevin O.
    What? You don't think a Ford will pull my new fiver? It's Ford tough you know!:-)
    Actually I just ordered a new truck today. See earlier thread:
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28160691/srt/pa/pging/1/page/1.cfm
    They are Ford tough!! My 2011 Ecoboost towed like an animal.:B
  • To Kevin O.
    Thanks!
    Mike
    I'm assuming you have a bigger truck and your not planning on towing that trailer with the F150???
  • I'd suggest you purchase a hitch that is the same as (or better) than the towing capacity of your vehicle. If your truck is rated to tow up to 16K, then go with the 16K hitch. If the truck is rated for more, go with the higher rating. My F350 has a towing capacity of 15,900, so I went with the 16K hitch.
  • In my opinion. Since this is the key component between my trailer and my truck. I didn't want to scrimp for a few $.
    When I ordered my hitch, instead of going with the 18k rating for my 17k (when loaded) 5er, I chose to go with the next higher rated one at 21K.
    The added level of mental comfort while driving down the road, especially of it is a bit rough, is sooo worth the few extra $.
    Gery
