Chuck_thehammer wrote:
Risk versus reward...
I do not weld with electrical/electronic equipment connected...
One error. your fault or NOT.. its DEAD.... all of it...
have you ever seen a lightning strike ... to electronic equipment... burnt toast...
read what happens when 220 volts is wired to a 50 amp RV service...
I know a person that did that to a NEW Georgetown....
The general point is reasonable (and valid), but all properly wired 50A RV service is 120/240 split phase service or, pretty rarely, two phases of a 120/208 three phase Y service. The problems usually arise from wiring 30A RV service to 240V rather than the proper 120V.
Welding generally involves comparatively low voltages and quite high currents. Problems, as I understand it, are more commonly due to induced currents in nearby conductors rather than zapping with high voltages.
