- Ron3rdExplorer III
love2rvcamp wrote:
We got a new 2013 F250. We are good to go.
Very good choice. Which engine did you get? - FisherguyExplorer
Congrats on the new truck!
You go with the diesel?
(You know no one's going to notice what you posted and will keep giving your advice, right?) :W - tatestExplorer IIGCWR, but it won't be in the door, rather in the owner's manual, tabulated across models, engines, axle ratios, whatever matters. Finding out the axle ratio might not be simple, if that's a GCWR factor.
GVWR and axle weight ratings, and corresponding tire sizes and pressures, will be on the DOT certifcation sticker in the door. That will be relevant to towing also, because you have to carry the weight from the trailer hitch within those limits. But finding out weight already on the truck won't be easy either. - love2rvcampExplorerWe got a new 2013 F250. We are good to go.
- pappcamExplorerA 1/2 ton with a towing package would be fine for an occasional pull to closer campgrounds but if you're planning on touring around I'd look at a 3/4 ton.
- ReferDogExplorerStay off the 1/2 tons, get 3/4 and you will have enough, gas or diesel,things change over time you might want a heavier unit later on.
- petenewellExplorerThere is a lot of good info in this thread. BurbMan and JBarca have excellent suggestions, in fact John's could be a sticky.
The details about "How To" get this right are here, the real issue is what you will talk yourself into based on other variables. Don't take this personally, we all do it to some extent or another.
The classic is someone that has a half ton, does not want to buy a new truck, then tows or hauls something that is too heavy. They then talk themselves into believing that it is OK because others do it or because they did not crash on that first trip.
This is hypothetical, I'm not putting words in your mouth, but lets say your DW was pressuring you to get the 1/2 ton, and or one of the imports because she likes those trucks for her needs. You could feel pressured to make that vehicle OK for towing and talk yourself into it when you shouldn't.
Like I said I think many of us do this to some extent or another. You are in a GREAT position in that you can start fresh and buy the exact right thing. - campiglooExplorerLot's of math available just to make sure you get the bare minimum truck required to do the job. You're investing a lot of money so why not invest enough to get good performance, comfortable driving and a safe ride that won't stress the vehicle?
- BurbManExplorer IIII'll just re-post my answer to the same question you asked in this thread. Ask the question any way you like, the answer is going to be the same....do the math of what you are planning to carry and tow, and see what your capacity requirements are. No acronym is going to do the math for you. In fact, I already did the math for you.
hmknightnc wrote:
Since you are buying a new TV and to ensure you don't end up with something on the edge or giving you poor performance I would recommend you do the following
- Look up your TT GVWR (not dry weight) and multiple that by 15%
- Count the number of people going traveling and multiply by 250
- Guestimate the amount of stuff you will have in truck
- add 400# for fuel and hitch
Add all of the above up and then look for truck with a door sticker payload/cargo capacity with that number or greater. This will get you truck that more than meets your needs for TT hauling.
Good advice and I'll try to help fill in the blanks...this model 2008 Rockwood 8313SS camper has a dry weight of 6501 and GVWR of 7784. Let's say the loaded weight is 7500 lbs. 7500 x 15% = 1125. Since 15% is on the upper edge of tongue weight ranges we'll assume that includes the hitch itself.
OP's signature says wife and 2 kids, so we'll estimate that people and cargo are 200 lbs each. 200 x 4 = 800 lbs. I believe that the factory sticker that shows cargo or payload capability already assumes a full tank of fuel.
So, 1125 + 800 = 1925 is the minimum cargo weight that you should be looking for. If you click the link above to the Ford website, there are number of 150's that will provide this level of cargo capacity and safely tow that Rockwood.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
