love2rvcamp's avatar
love2rvcamp
What acronym should I look for when buying a new TV
Looking to buy a new TV to replace 2001 F150 to tow our 2008 Rockwood 8313SS.
We are looking at a F150 (5.0 or the ecoboost) or a Tundra.
What should we look for specifically when looking at towing limits/ratings. GVWR, GCWR,
We just want to make sure we read the door sticker correctly and know what numbers we need to watch for.
  • JBarca wrote:
    ....snip.....
    A F250 and a F150 are not that different in price now if you are going to a much heavier loaded TW camper in the next few years. If your staying in the same weight range, then life is good.
    Just for kicks I went to the GMC website and "built" a 2014 Sierra 1500, and also a 2014 one ton dually. $48K or so for the 1500, $54K for the 3500. I was shocked they were that close in price.
    The 3500 I priced out was a gas engine.
  • X2 fisher guy. For me, with a trailer very similar to yours, I find the 3/4 ton diesel the only way to go. I live in S. La. and it's flatter than where you are. Have towed smaller, lighter trailers with 1/2 tons and yes, it moved them from point A to point B. The overall performance of the rig IMHO is well worth the extra initial investment. My Cummins chugs along @ 2000rpm @70mph. In W.VA a couple of weeks ago, we hit a 9% grade about a 1 1/2 - 2 miles long, 60 mph @2000rpm in 5th gear:awesome! My experience is that a gasser is going to hum at a much higher rpm., use more fuel, strain the tranny, rear end, brakes and suspension. Since I grudgingly went to the diesel two trucks ago, I will probably never get another gas truck. I went to one vehicle dealer and he guaranteed this 40hp riding mower would pull anything! LOL Anyway, best of luck with the new truck, whatever you choose
  • rockwood 8313ss
    I know the above link is for a different year, but that's a 34 foot trailer with a GVW of 8500 pounds, I don't think any 5.0 gas powered half ton or Toyota is going to be able to handle something that big unless it's pretty flat where you live and where you're going.
    First off, good for you on doing some homework trying to figure this out for yourself.
    Since you already own the camper and have a truck, suggest doing this "first" so you are armed with real world weights. No guessing or him hawing and no one saying, sure it will pull all day long.
    Load up your present day truck with what ever camping gear is going in the truck bed and the cab. That includes people too.
    Also load the camper the way you go camping.
    Now head to the truck scales. If you have a good idea you are already in weight issues, make 2 trips.
    Truck only, Weigh the truck front and rear axles loads with gear/people in the truck. Then go back and weigh the empty truck. Do some math. Now "you" know exactly what what the truck has to handle from a cargo perspective.
    On the second trip when you are empty, take the camper fully loaded the way you are going camping. Pull the camper and truck on the scales and unhook the WD bars but yet still hitched. You need a front & rear truck axle weight and the 2 TT axles on a separate scale. Take a weight. Then hitch up the WD bars, pull off, unhitch in the yard and go weigh the empty truck. Do some math and now you know the loaded weight of the camper and the loaded tongue weight. You need the WD bars off to do this as they shift weight to the camper axles.
    This costs you, some time and about $14 to $20 dollars for the truck scales. Now "you" are armed with real weights, no fudging, no guessing before you pay good hard earned money on a new truck that might be OK or not.
    The rear axle on the truck in a 1,500 series truck is the weak link. The rear axle and receiver WD rating generally follow what the rear axle can handle, but not always. You have to check From the scale weights you know the bed cargo weight on the rear axle and just figure the actual loaded tongue weight to be handled by the rear axle. Technically WD removed some of the rear axle weight to the camper however this will be a saftey cushion for you.
    Pulling, since you know the actual loaded TT GVW, find the the actual empty GVW of the new truck you buying with all the options. Then add to the truck weight the truck cargo and people. Add all 3 weights and this creates a GCW. You are going to need some reserve towing capacity for loose of frontal area of the wide and tall camper. Everyone has a different comfort level of reserve capacity however more is better. 1,200# to 2,000# is good, more is great for your combo. Compare the GCW of your actual plus reserve to the new truck rated GCWR.
    Once the rear axle/receiver fits and the GCW fits, you need to check the GVW of the truck agasint the GVWR of the truck. If your still good, then OK. If not, well you have to loose some weight/cargo or figure if you can **** to the camper
    Here is another tip, LT tires. Ford use to offer a LT upgrade on the F150, While they are D load range, they are better than the standard P rated ones. The LT's will create a more stable towing experience.
    Hope this helps and good luck
    John
    PS. Also think, Am I going to upgrade this camper is a few years or not? Now is the time to figure that out. A F250 and a F150 are not that different in price now if you are going to a much heavier loaded TW camper in the next few years. If your staying in the same weight range, then life is good.
  • If the door sticker lists a "maximum cargo weight," that's the one which will be most useful to you.
    You then need to know:
    1. The weight of wife, kids, and whatever else you put in the truck to go camping.
    2. The tongue weight of the trailer, as it is ready to go camping.
    If 1 + 2 <= cargo weight capacity of the truck, you are golden.
  • BenK wrote:
    Below is my diagram showing how the specifications/limits/ratings system works
    Best to weigh your setup axle by axle fully loaded ready to go. If you don't
    have one or the other, then use their GVWR's as the potential max...if you load
    everything like most do...few are truly light in the stuff they load
    Also, decide if you believe in the ratings or not.
    If not, then do whatever but a new 2013, assume still under warranty. so know
    that if they find out over loaded, warranty might be denied (I would if I was
    the OEM)
    If yes, then check out the below diagram, gather the specifications for 'your'
    TV and plug in the actual weights to do the simple math.
    You have found out that it is not all about go, but the ratings are the true
    measure. You will get tons of 'sure you can', etc, etc advice, but there is only
    one person responsible for the setup and that is the driver, who might not be
    the OP, but a buddy or spouse. Then the OP should ask themselves if the advisers
    would pay for any overload break down?
    I do not advise with the 'your are good for it', 'sure you can', 'no you can not'
    but provide the metrics for the OP's to figure it out themselves...I have to
    sleep at nite as I take providing advice seriously...
    This is NOT a half ton can't tow anything...everything can tow
    and then they also have specifications/limits/ratings on what they
    are 'rated' to tow.
    Just that half tons have lower ratings and head room than bigger trucks
    Then note that there is a huge spread on 'half tons'. From less than
    6.2K GVWR to over 8.1K GVWR (I call them fake half tons). So many
    get bit by hearing/reading of a 'half ton' doing whatever but miss
    or the poster didn't say they have one of those fake half tons. I've
    gotten several PMs about that and one guy so mad he wanted to sue the
    guy telling everyone a half ton can, but he had one of those fake
    half tons...so this guy who PM'd me burned up his diff towing what
    he though all half ton's can because one guy said he does and advise
    that guy he too could...
    another thread titled: New guy needs help
    BenK wrote:
    Welcome to the forum !
    First decide if you believe in the OEM specifications/limits/ratings or not
    If not, then do whatever but note that if there is warranty left...the
    OEM may be denied. If no warranty, then you have taken the OEM off the
    liability hook
    If yes, then read up and ask lots of questions
    There is a huge difference in how a question is asked or answered
    'Can do' is way different from 'should do' or 'rated for'
    The specifications, limits and ratings is a 'system' and most take
    a single rating as an absolute or out of context....like your reference
    to your TV's MTWR (Max Tow Weight Rating)
    Meaning that, those MTWR's are only a true rating within the fine
    print of the OEM's specifications
    Meaning that they derived those MTWR's from a 'curb' weight TV, which
    is the 'stripper' model with no options other than the tow option
    and one 150lb driver. Some full fluids, others partially filled
    Best is to weigh your TV's fully loaded...axle by axle. That is the
    only way to figure out your 'true' MTWR
    You should gather these ratings for both your TV's
    GVWR
    FGAWR
    RGAWR
    GCWR
    Then do the simple math to figure out your true MTWR
    Some come here looking for confirmation of what they want to hear
    or what they have already decided on....they WILL get many advisers
    that will do exactly that...just ask yourself if those advisers will
    provide the funds for warranty or whatever cost an overloaded TV
    might suffer
    This image shows how the ratings system looks like in graphical form
    howmuchcanitow
  • Chuck&Gail wrote:
    We were told Toyota doesn't spec tongue weight so they can avoid any litigation from folks using them to tow. True, no idea, but certainly Toyota was unable to provide any proof of specs in ANY printed literature. Personally we crossed Toyota off as a potential TV. Hopefully you will have better luck.
    Do remember if salesman says anything, it does not count unless he can back up his works with manufacturer documentation.
    Often, "what we're told" and "what's true" are not remotely related.
    I think the salesman you spoke with needs to take some coursework at Toyota University if he/she wants to sell trucks to educated buyers.
    There is no conspiracy for Toyota to avoid litigation...they, like every other automaker, get sued all the time.
    Toyota lists the following in the Tundra owner's manual:
    1. Vehicle capacity weight - the weight of all occupants, cargo and tongue weight.
    2. Max trailer weight.
    3. GCWR
    4. Recommended tongue weight (defined as 9-11% of gross trailer weight for trailers, 19-21% for fivers/goosenecks)
    Additionally, they list the GVWR and GAWR, plus other info, on the certification label on the driver's door jamb.
  • You need 13% to 15% of the FULLY LOADED TT weight on the TV tongue. Almost always the TV limit is its tongue weight spec. Not the receiver spec, the VEHICLE spec. When we went looking in 2010 Ford, Chevy, in fact almost every SUV or pickup we looked at had a spec the dealer could easily find.
    BUT
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
