myredracer's avatar
myredracer
Explorer II
Jun 06, 2019
What adapter for Prodigy P3 & GMC?
Looks like we're unexpectedly buying a 2012 GMC 2500 because our F250 just died far from home (see post in tow vehicles). Our F250 has a Prodigy P3 brake controller I'd like to install in the GMC. Is that possible or is the GMC designed to have a factory b/c only? It has no b/c controller now.
I just did a little googling and can't seem to find the answer. I need to get the GMC all set up for towing our TT for the next camping trip in a couple of weeks and need to order a new adapter cable if available & needed.
I really like our Prodigy P3 and would rather keep it if possible.
  • MFL wrote:
    If it has the 7-pin connector under the bumper, it likely will have an oem supplied connector/adapter in the glove box. With Ford these oem connectors need to be hard wired to the controller, but very easy to do, especially for an EE. :)
    Jerry
    You just need the standard vehicle side pigtail that came with the P3, the GMC will just have wires without a connector.
    A 2012 GMC will have a bundle of wires taped to a brace above the brake pedal. This is from memory. The GM blue goes to blue on the P3 pigtail. The GM blue with white goes to red on the p3 pigtail. The GM red with black goes to the P3 black, and the GM white to the P3 white. There may be an orange wire, don't worry about it.
    Now go to the underhood power center and find the red wire that is bundled and stuffed between the power center and inner fender towards the rear of the plastic housing. Connect this to the inner stud located on the front of the power center. You need an 8mm fine threaded nut. You may have to install the fuse to power the stud, 30 amp IIRC, this powers up the controller.
    But like MFL said the truck has to have the factory 7 pin out back. If it doesn't chances are it is also not pre-wired for the controller.
  • I've used my P2 on 3 different tow vehicles. Very easy to move and connect. The P3 is no different.
    On GM's the wiring for the brake controller is above the kick panel under the steering wheel. Sometimes they have a connector that only requires a pigtail. If that isn't there they will have the wires bundled with black tape at the end. You'll be able to remove the pig tail for your F-150 and simply wire into the Sierra. If there is a connector under there, call Tekonsha and ask what pig tail you need. Their tech support is really good.
  • If it has the 7-pin connector under the bumper, it likely will have an oem supplied connector/adapter in the glove box. With Ford these oem connectors need to be hard wired to the controller, but very easy to do, especially for an EE. :)
    Jerry
  • Not familiar with Prodigy P3 but my P2 is connected to my Chevy with an available pig tail to a plug under dash. Factory brake controllers were unheard of those days. If your '12 GMC comes with factory towing package, there must be a plug somewhere under dash. Call Prodigy's customer service and they probably can rush you one of those harnesses. If not, hardwiring these controller to the brake light circuit is relatively easy. Even I can do it.
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 04, 2025
