D_E_Bishop
May 15, 2018Explorer
If you have a winegard, you,re set to go. If you are having problems wit it, replacing the "f" connecters, adding a wingman and the sensar pro, you will really on top of the OTA antenna.
You probably have a B.O.M.B. and that will take care of switching between anything with coax cable.
BluRay will require a HDMI cable and that will connect directly to the TV set. That is accessable from the INPUT function inthe TV.
Not a big deal, really easy. A lot more help here if you need it.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
