jplante4
May 16, 2018Explorer II
bigred1cav wrote:jplante4 wrote:
I added a Wingman to my old Winegard batwing and replaced the antenna switch box with a Sensar Pro booster and signal strength meter. I get great HD digital OTA almost everywhere. I even got Houston stations in Galveston.
At the RV parts store where I work part time, we sell a couple dozen "tech" antennas (King Jack) a season all taken out by a low hanging branch.
Do those antenna just replace by taking off old one and attaching new to standard of old one?
Do they work off same handle in coach?
Thanks
You remove 3 rubber plugs from the bottom of the existing batwing, put the Wingman on the bottom of the batwing and put the 3 rubber plugs back in. It takes longer to set up the ladder than it does to add a Wingman. As long as you have clearnace around other appliances on the roof, it goes up and down like the original antenna.
Video
The installation is the last 15 seconds of the video.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 08, 2026
