bikendan wrote:
Cummins12V98 wrote:
P2 is a POS. You should never have to change settings depending if you are driving stop n go or freeway. I have heard the P3 is MUCH better.
have you owned a P2?
i've owned mine for over 10 years and it has performed flawlessly.
i have never heard anyone call the P2 a POS, in 12 years of being on 6 different RV forums.
Yes and it was adjusted properly. You had to change the setting while going thru a Campground or it would put you thru the front windshield. Scary part if U did not return to the heavier setting you basically had NO brakes on the highway.
