rtaylor0830's avatar
rtaylor0830
What brand battery
I need to replace my battery on my rv. I do not boondocks hardly ever but I do not know what kind of battery to get. I only want to put one on so what would you guys recommend. I have seen some that are sealed are they better.
  • coolbreeze01 wrote:
    Only one battery? Most any brand will be fine for your use. I'm using Interstates. Have fun.
    agree .... Interstate Group 24 Deep Cycle
    Jim
  • Ever start from Wally World would be your best bet!! I have had good lick with them,, last right about five years or more,, Cheap and plentiful!!
  • If you don't boondock then get the cheapest battery you can find. No sense spending lots of money on amp hour capacity that you will not use. Good luck!
  • Only one battery? Most any brand will be fine for your use. I'm using Interstates. Have fun.
  • I have gone to AGM construction batteries in everything .
    If you Wikipedia AGM you will get a good overview of why they are better than conventional lead acid batteries .
    I purchased Exide EDGE AGM batteries for $140 each at BiMart (Oregon )
    they recharge faster.
    they do not spill or corrode
    they can be drawn down further than conventional .
    For Very serious dry camping it is better to go to 2 golf cart GC2 batteries .
    The 6 volt are not available from exide EDGE AGM construction .
    For dry camping we hook up our 2 AGM batteries in our diesel pickup to the 2 RV batteries with a # 2 AWG jumper cable 12 feet long .
    We do not run the truck engine to recharge the RV batts .
    A drive in the pickup every 2nd day suffices .
