komodo's avatar
komodo
What grease is best for repacking
I have a AL-KO Ultrulube. It says that I need to use NLGI Grade 2 lithium complex, grease with a minimum dropping point of 400F for the repack.
http://dutchmen.com/image/data/documents/parts/alkobrochure.pdf
The only grease I can find in our local shops that indicate dropping temperature is Quaker State Multi-Purpose Grease and Wheel Bearing Lubricant. It has a 525F dropping point, but it does not say "Lithium complex"
The other choice I have is Mystik Hi Temperature Grease, it has "Lithium complex" but does not say what is the dropping point is.
Does anyone know if one of these products will work?
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Oct 01, 2015
