rtaylor0830's avatar
rtaylor0830
What is the difference between regular silicone and proflex
Just wondering why you should not use regular silicone around the seams of windows and other seams.
  • Old-Biscuit wrote:
    Silicone won't stick to silicone.......nor will anything else until all silicone has been removed and then the residue left behind removed using a solvent.
    Silicone does NOT belong around an RV.
    Use Dicor or Proflex
    X 2 !!!
    B.O.
  • Proflex is what the dealers use for waterproofing, and it's more like 1/2 sealant and 1/2 adhesive.
    It's some great stuff.
  • Silicone doesn't stand up to the rigors of an RV, it eventually degrades and loses the bond. Proflex is a three part polymer that has excellent bond strength and elongation.
  • Silicone won't stick to silicone.......nor will anything else until all silicone has been removed and then the residue left behind removed using a solvent.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
