Son_of_Norway's avatar
May 17, 2018
What is the safe way to fill a propane tank?
I run into three types of propane fill attendants. (Class A horizontal) One just connects to the valve and fills the tank. Another opens the bleed valve as they fill the tank until propane sputters out. The other kind first bleeds the tank then connects to it and fills it. Each kind says that their way is the only way that they have ever done it and they have never even heard of the other ways. Which person is right? Thanks.
  • The right way is option two. Connect open valve, open bleeder, start pump, when propane comes out of the bleed valve, close vslve, stop pump, close bleed, disconnect. The bleed valve is what is called an 80% valve. It is intended to allow liquid propane out at 80% of tank capacity.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
