lizzie's avatar
lizzie
What kind of tape to put signs on TT
My Road Call Alaska signs are made and I want to tape them to the back of our Keystone Bullet. They are made like plastic real estate signs.I want them to stick for the trip but not forever and I don't want to ruin the finish on the TT. Any suggestions? lizzie
  • lizzie wrote:
    Thanks everyone. The signs are larger than I had planned & will block the windows. I would post pictures but have NEVER had any luck with that on this forum. lizzie
    You do realize that it doesn't get dark in Alaska in the summer so blocking windows is good! :) Seriously, are there a couple windows in the bedroom that it doesn't matter.
    You might also chalk it up as a bad purchase and get some smaller ones for the windows. Two years ago folks even made their own signs on their printer, laminated them and put a couple in the windows. Others hung them from the rear ladder, if you have one.
  • Thanks everyone. The signs are larger than I had planned & will block the windows. I would post pictures but have NEVER had any luck with that on this forum. lizzie
  • DrewE's avatar
    DrewE
    Explorer III
    Gorilla tape might be a decent option. I've never tried to remove it, but I think it tends to come off a little more cleanly than normal duck tape.
    Taping to the inside of a window (if you have one in an appropriate location) is probably the best idea.
  • Do you have a ladder on the rear of the RV. Punch some holes and hang them.
    Otherwise, they sound like heavy signs and I doubt they'd stay on during the Alaskan trip. Putting them in a window would work if they're not tinted windows.
  • Murphsmom wrote:
    I would use the blue painters tape and attach the sign to the inside of a window.
    I used clear packing tape. When I remove the sign, the tape came of OK with a razor blade.
    Please post a picture of your sign.. . . :)
  • I would use the blue painters tape and attach the sign to the inside of a window.
