NanciL's avatar
NanciL
Explorer II
Nov 19, 2016
What sealant or caulk to use ?
I have a leak in the connection between my fresh water inlet and the inside pipe and need to take the outside flange/connection fitting off to get to it.
What is the proper sealant or caulk to use when I reinstall it?
Please don't answer unless you have done it or are an RV tech who does it a lot
Jack L
  • Butyl or putty tape. For extra credit you can drape a bead of ProFlex RV caulk over the top half of the fitting flange. That is what I do.
    Good luck with the fill tube. I hate those, they always leak at the ends where clamped. It's a poor design. Seems like I say that a lot about RV stuff. :)
  • poppin_fresh wrote:
    Most of the items stuck on from the outside such as the water inlets, power cord cover, etc., are all sealed using butyl tape. It's basically just a putty that makes a seal between the trailer and whatever.
    I replaced several items on my last trailer and used butyl tape to reseal them all as that was used by the manufacturer.
    Thank you,
    I'll see if I can get some
    Jack L
    Correct .... normally caulk/sealants are only used as a secondary seal. While there might be others two other specific adhesive/sealants made for bedding fixtures are the 3M Marine 4000 and 5000 series Marine products which are my choices to use as a secondary caulk/sealant in addition to the normal butyl tape.
    A final option to use in stead of butyl tape would be the double sided Eternabond tape.
    Larry
  • I'd use a Geocel polymer sealant. They endure UV and weather greater than any other sealant I've used.
  • Most of the items stuck on from the outside such as the water inlets, power cord cover, etc., are all sealed using butyl tape. It's basically just a putty that makes a seal between the trailer and whatever.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
