CALandLIN
Feb 21, 2019Explorer
fj12ryder wrote:
Actually Keystone "derated" the axles to get the tires to meet the tire/axle rating. They are 7,000 lb. rated axles, according to Dexter when I checked with them, but Keystone "derated" them to 6,800 lbs. so the "E" rated tires, at 3,400 lbs. each, would work.
How's that for working with the numbers. And a CYA.
Keystone and a lot of other RV trailer manufacturers got into a "catch 22" with those 7000# axle certifications. The easiest way for them to remedy it (IMO) was to deduct a couple of hundred pounds off the trailer's cargo capacity and derate the axles which they are allowed to do. The culprit is the ST235/80R16E tires. Different tire manufacturers have used different load capacities for that identical sized tire. 3420# and 3520#, both at 80 PSI MAX. The 3420# tire does not qualify for use as OEM on 7000# certified axles.
Reason: Elsewhere in the FMVSS there is a standard that says when two identical tires have different maximum load capacities they automatically default to the lower rating.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
