Old-Biscuit
May 08, 2016Explorer III
So you have a Suburban WH.......cause you tried the Push to Reset Buttons
Now remove that cover and check the set of t-stats.
Black wires....120V AC (Left side)
Red wires......12V DC (Right side)
If wire between top (Hi Temp---Resettable t-stat) and bottom (Normal t-stat) is burnt into...power stops at the top t-stat
Propane System'
12V DC from FUSE to ON.OFF Switch to T-stats to control board (on backside of tank) to gas valve/spark electrode.
Propane System'
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
