Blanco1
Oct 15, 2014Explorer
tpi wrote:Just some lights & the fridge.
Do check out the threads on LED upgrades. Some is just a matter of replacing a bulb with LED equivalent.
The primary duty of that battery isn't starting. Don't concern yourself with cold cranking amps. The applicable spec for you is amp hour capacity. Try to get as much over 100 in the box as you can. A couple of the suggestions posted above were for 150 and 160 amp hours. This would be great upgrade over what was in the box originally.
Thanks
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
