wa8yxm
Aug 01, 2021Explorer III
Whatever you use remember two things
Chock before you unhook
Remove chocks after you hook up
I have seen what happens when people forget.. both those things (Flying plastic bouncing off very expensive motor homes and possibly causing injury in the 2nd case... Rig headed toward the lake in the first... thankfully there was grass once it rolled off the pad and the jack dug in and stopped it. HINT to stop trailer fraster. Do not pull the safety chains, do not push/pull the Trailer itself. Pull on the break away cable. if the battery is good that'll stop it .. SWIFTLY.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
