cbshoestring's avatar
cbshoestring
Explorer II
Jun 09, 2022
When the water pump turns on by itself.
We started out this week long trip at a state park with just an electric hook-up. Not long after settling in, I hear the water pump kick in, even though no one is using water. My spidey senses alert me to trouble.
Sit and listen. Yep, there it is again. The pump did a quick on and off.
NEWBIE ALERT: Pressurizing your water system using the pump is a good way to check for leaks. The system should hold pressure. If the pump turns on by itself....find the leak.
The toilet bowl was almost overflowing. Apparently the valve was leaking...luckily into the bowl.
Picked up a new valve on the way to 2nd camp ground. Not a major deal with some basic hand tools. Quick removal of toilet. NO...those chemicals do NOT make the black tank smell citric lemony fresh. Quick change of the value. Reinstall toilet.
Very thankful that I caught it BEFORE overflowing. Turning the pump on, only when needed...keeping an eye on the bowl, sure beats the mess it could have been.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
