- turbojimmyExplorer
Blanco1 wrote:
Something I'll look into.
Make sure you look for the right height. They're more or less standard in size: 17" tall or 21" tall. The T2130 is 17" tall. Width seems pretty common, too, at 21". The new "Vision Series" Atwoods appear to be a direct fit, but are $600 new. Take-outs are around $300. I've seen a couple of used ones in the low-$200 range but they look pretty beat. - Blanco1ExplorerI can't justify the price of replacing the oven.
I'm like Jimmy, For as often as it would get used it can wait.
My tummy & wife would both enjoy a working over though.
I never really thought about finding a whole replacement oven though.
Something I'll look into. - turbojimmyExplorer
Old-Biscuit wrote:
His doesn't work either.......
No parts...oven is obsolete
Time for new oven
Yeah. I can get a new salvage one ("removed for upgrade...") for about $300. For as many times as I might use the oven, it's not worth it. I'm going to keep my eyes peeled for someone junking an RV locally. - Old-BiscuitExplorer III
Blanco1 wrote:
turbojimmy wrote:
Blanco1 wrote:
Still looking for this oven valve & or links or numbers to possible sources?
Thanks.
I have the same range in my '84 (T2130BG). Oven is inop. Pilot works, but the oven doesn't come on. I cleaned the thermocouple by the pilot . No good. Can't find parts anywhere.
Any other suggestions? Or do I need to replace the whole range?
Sell me your over valve!. :D
Time for new oven - Blanco1Explorer
turbojimmy wrote:
Thanks.
Sell me your over valve!. :D - turbojimmyExplorer
Thanks.
Any other suggestions? Or do I need to replace the whole range? - Blanco1ExplorerStill looking for this oven valve & or links or numbers to possible sources?
Thanks. - rhagfoExplorer III
enblethen wrote:
These people should be able to help depending on the model number.
Laurelhurst Distributors
Great company, and I am lucky enough to live in Portland, so I can go directly to the source. - Blanco1Explorer
enblethen wrote:
I did not find your part number in my sources. (12130 BG)
Would you verify it?
You may find a make and model on the gas valve it self. You might look on it.
After our trip I may remove the valve itself & get the number off it, yet I wonder if I could rebuilt it?
Just clean it out?
Maybe its a simple blockage? - Chris_BryantExplorer IIShould be a T2130, and pretty much nothing is available for that, unless you find new old stock, used, or rebuilt.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
