mommie53241's avatar
mommie53241
Where can i get one of these i cant find them anywhere
Its on a Lance 1052 but have searched the web for hours and cant find on and its exactly what we need.
  • Did you find exactly what you were looking for, the one in your picture?
    If so, where? Thanks.
  • Amazon has a variety of USB chargers with standard 120V outlets. I've bought two of them, they work very well.
  • Depending on what you intend to use the 12V outlet for, Make sure that you wiring is sufficient to handle it. If possible, these should be on at least 14 or 16 gauge wire, and protected with an in-line fuse if possible.
  • Victory402 I found it here-Ebay-Waterproof Dual USB Charger and 12V Heavy Duty High Power Socket, Dash RV Marine :)
    the 12v outlet will just be used for a 12volt tv I believe we are going to use 14 gage wire better than 16 lower the number better the wire
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Lower the number, the bigger the wire (generally).
    Thanks Mommie. I'm actually more interested in the more residential style you have pictured from your first post. The one Lance uses.
    Anyone know where one of these can be purchased?
  • Some of those ebay/amazon ones are complete crap. I went with blue sea stuff, it's spendy but better quality.
