luberhill's avatar
luberhill
where or can I get LED bulbs ?
Three of my MH's interior ceiling lights have what I think are NOT LED bulbs, they have a switch on the side, oval and have two little bulbs that get hot
Can I get LEDS for these or isn't it worth it ?? Just to save battery juice when dry camping
Thx
  • Great, which ones on Amazon did you get and are they sufficient lighting ?
    I think these are 921 bulbs I’ll check in the morniing, May as well replace them all
  • luberhill wrote:
    enblethen wrote:
    Are they like this? Uses a 921 lamp that can be easily changed to LED lamps.
    Optronics lights
    Umm not really...they are oval, two bulbs inside, switch on the side...one over the bed, one in the bath, one in the main area...squeeze the clear cover and then you can see the two small but HOT bulbs inside facing each other...
    They may be the same bulbs in your pic but the fixture is different
    Pull a bulb out and there should be some markings on it. From your description, my lights are quite similar. Queried the bulb number and LED and found a place to order replacements on Amazon. Had 24 bulbs to replace, super easy peasy to do. Practically no impact on battery drain, compared to the bulbs that were replaced.
    Optronics lights
  • Definitely worth upgrading to led. They run much cooler and draw less power.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
