Eddiegnz1's avatar
Eddiegnz1
Where To Dump Black Water When Dry Camping
we will be dry camping on a friends land that is over 1,000 acres in Florida. WE'll actually live there for a year or maybe even two years. The property owner (my good friend) said I could simply dig a ten to 12 foot deep hole and put a 4 foot by 4 foot piece of plywood over the hole. The plywood would function as a lid and decrease odors from escaping because the plywood would be almost entire buried under dirt. The only part that would not be buried is the plumbing part that attaches to my black water tubing/line. The hole would be about 18 to 24 inch diameter. Then I could attach/install the plumbing fixture on to the plywood and then hook up my black water hose to the fixture. Then each time i dump, just remove the plywood and bury the black water with 12 to 18 inches of dirt and repeat layering like this until the final layer of dirt is 24 inches thick. Then dig another 12 foot deep hole else where to start a new dump site.
It's his property, he's not an experienced Dry Camper nor experienced in RV'ing. Which is why i'm posting this question to you more experienced folks.
Can his plan work?
have you ever tried something similar?
Please share your suggestions, recommendation, advice. Thank you kindly in advance.
Eddie
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
