Nevadastars
Jan 13, 2017Explorer
burningman wrote:
I put mine inside under the rear seat.
Noise is not an issue whatsoever, you only run it when you're airing up your bags, it's not like it's on all the time. It doesn't run long enough filling your airbags for air circulation to be an issue.
Completely out of the weather and water is best, that's why I put it inside.
Plumbing isn't a nightmare. It's easy.
Having said that, I also have one mounted underneath on the frame that's been there for years and it still works.
Just thought I would post up that I got the compressor and bags installed. I did mount the compresser in the compartment under the rear seat drivers side. It is a lot smaller than I thought it would be and worked out well. I also mounted the gauge in a factory pillar pod, it also turned out great and is easy to reach to add or let air out. Below are a couple of pics....
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
