shades9323's avatar
shades9323
Where to start with wdh adjustment for new truck?
Got rid of my Ram 1500 with 1300 payload for a Silverado 2500 with 3300 payload. Same Jayco x23b hybrid with 5-600lbs on the tongue. Equalizer hitch.
The 2500 sits higher so I know I will need to drop the hitch down a notch or 2. Where should I start with attachments on the A-frame?
  • MFL wrote:
    You may not need a WDH with the new truck. Have you tried towing it without? Just 5-6 hundred lbs actual tongue weight will not remove much from front axle of a HD truck.
    Jerry
    Haven’t tried it yet. Just got the truck last weekend and the camper is still in storage. I figured that I wouldn’t need the weight distribution, but my hitch has sway control. Probably still want that.
  • You may not need a WDH with the new truck. Have you tried towing it without? Just 5-6 hundred lbs actual tongue weight will not remove much from front axle of a HD truck.
    Jerry
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
