I have a 2014 Silverado 1500. I just bought a TT. Passport 23RB. dry weight;4730, tongue wt; 525. Length 26’. I was sold an Equalizer E4. Friends strongly recommend Reese Dual Cam. I’m a new...
The Equal-izer 4-pt is a good WDH with integrated sway control. The owners satisfaction rate seems to be about the same as the Reese dual cam system, both quite high. I would not change one for the other.
The EQ like most WDHs can be failry easy to hook up using the following procedure:
Lower tongue onto ball just enough to latch Latch tongue on ball Raise tongue/lower jack Install WD bars Lower tongue/raise jack
That procedure is greatly assisted with an electric tongue jack.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
