Sam_Spade
Mar 01, 2018Explorer
westend wrote:harvey wrote:Not my experience.
If you have more than 13 volts when using lights you need the ones with voltage regulation.
Not my experience either.....at least not specifically the way he worded it.
It depends upon how close to the "flame out" threshold the ballast resistor is designed to run them.
Super cheap ones likely won't perform good with over-voltage. Slightly better ones designed to operate at a bit less than max. brightness should be fine. Should be.
Try a couple first before you order a whole "set".
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
