centerline's avatar
centerline
which LED bulbs for interior lighting??
Im sure this isnt the first time someone has asked this, and Im sure there are still a lot of others who wonder about it...
the LED bulb market changes quickly, and when someone makes a bulb that is nearly perfect and can produce it for a few cents, someone else will recognize the money grubbing potential and buy a license to market the bulbs, and Jack the price up til its nearly un-affordable...
BUT, there are still good bulbs being made that are excellent quality that ARE affordable...
and some of us would like to know which ones these are.
I have found the Green Value LED bulbs in the natural white color to be great for the interior lighting, as they are easy on the eyes for reading, and bright enough to "feel" good, whereas after awhile, a low light level can make one feel like they're setting in a dungeon... most of us dont like that atmosphere.
the color of the Green Value natural white bulbs is right, without the "blue" color, and not so soft as to have the yellow color either.
and at 270lumins, they are plenty bright....
the down side is the cost...
maybe not so expensive for a couple of bulbs, but my trailer has 30 bulbs that I want to change to led... at the cheapest price I can find on the green value 1156 style bulbs, that equals about $150...
I would like to hear from others who have bought OTHER brands of cheaper bulbs and are FULLY satisfied with the color and brightness of them...
AND it would be helpful to know which bulbs to stay away from, due to the eye straining color or low light output....
my cousin was down at Quartzsite 2 yrs ago and bought 10 bulbs for 2.50 a piece that are great, and one cant tell the difference between them and the $5-8 dollar bulbs.... these are undoubtedly available online somewhere, probably even cheaper, if we only knew which bulbs they were...
thanks for your input...
  • If you get the voltage regulated bulbs, they might blow away TV reception when using the antenna. Usually they quote a wide range of voltage like 12 to 24. The cheaper 12 volt only might be fine but have a shorter life. I am dealing with this right now having regulated bulbs causing interference, now a batch of unregulated that are too dim and waiting on yet another batch to try. It’s still a crapshoot out there.
  • I can't give you a brand but E Bay sells thousands of these LED bulbs and for short money. I'd suggest to pick out a few and try them. If they meet your needs, buy enough for the whole replacement. I bought from seller "2011_LED", based in China. The service was fairly fast and all product performs as advertised.
    Good luck with the replacement, it saves a ton of battery power.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
