cummins2014
May 03, 2020Explorer
dodge guy wrote:
The repeater is wired into the 12v system. You could run a dedicated wire from an ignition source all the way at the front of the RV. Or you could hardware it into a constant source which is what I did. When mine is in storage the 12V system is shut down, but if you want you could install a switch in line to shut it off or just pull the fuse. The amp draw is minuscule. It wouldn't drain the battery even after a week or 2 of being left on. I just don't want to keep,it powered up when not needed.
BTW. I took my RV back tomstorage yesterday and with the repeater it kept all the sensors readin on the display, without the repeater the rear would drop out occasionally. I didn't have he car attached so I can't say how well that is, but I didn't see any issues.
I did just that ,wired in a 12 volt switch for my repeater, right next to it in my battery compartment of my fifth wheel. Plenty of 12 volt sources there to hook to. I want to turn it off when not in use. My fifth wheel is plugged in 24/7 beside my house .
As said before TST seems to be the brand to get. I have been happy with mine ,not sure what else you could ask for on a system. Mine supports more tires then I would ever have. Simple to program, easy installation etc. I noticed one not happy with their website, not sure what more there is to know about TST, but I have never been on their website, so not sure what one needs to know that they don't provide .
In a nutshell, the TST 507 monitors as many tires as you could possibly want, it has low pressure warning, high pressure warning, and high temperature warning . I don't know what else there is to want on a TMPS.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
